Hello. I have obtained a jvc rc 656 and most of the issues i have fixed with it except for one. The radio doesn't seem to tune in stations correctly. When i get to a station that should have good reception you can hear the radio cutting in and out of the station really really fast. Like it tunes it in and cuts it out 2 - 3 times a second then it might keep it cut out for a little while and some timed it will come in for ay most 1 second.
When it tunes it in, you can see the tuned light light up and when it cuts out, the tuned light turns off which means there is some issues with it getting the channel in i guess.
I gave the band selection switch a few good size doses of deoxit and let it dry for about 20 mins. After that i hooked it up and it seemed that the unit was working fine. It was doing a great job tuning in the stations. I then put a cassette in and after listening to the cassette i turned the radio back on, and it seemed to start with the same issue.
Note: When i intercept the radio with the line in on the side of the boombox with my ipod the music plays fine. No cutting out from my ipod, but when i unplug the connectors and go back to the radio it will do the cutting out.
Any suggestions on what may be the cause of the cutting out? Thinking there is some connection issue but not sure.
