After seeing 2 recent threads about GE decks with the infamous head issue, I am really curious about exactly how prevalent this issue actually is. I suspect that most if not all decks on the beloved GE 3-5259 Blockbuster and Realistic SCR-8 14-778A boomboxes are now suffering from the broken head mounts but I'm just guessing since I've not personally owned one single example without this issue and I've owned at least 4. I'm hoping this poll might shed some light on this.
Rules:
If you purchased the boombox brand new, obviously it WAS working at that time, in which case, please ignore the first choice and use it's present condition to answer.
Answer only if you own or have owned these boomboxes, since this poll otherwise doesn't affect you.
You may answer if you have a model that has the same or similar deck with this same issues, (probably other GE models.)
You can make more than 1-choice, in case more than 1 choice applies to you.
I tried to include all the possible choices I could think of. If there are other choices you think I should add, let me know, although not sure I can change this poll or not after the thread is posted.
Depending on how this poll goes, I might start other such polls on other models.
Rules:
