Received my near mint RS-4360dft from a member in the other forum today. It was bubble wrapped, 1 or 2 layers and put into a box, which was then stuffed in another larger box with balled up newspaper cushioning material. I had a bad feeling when the box arrived soft and you could feel there was lots of void between the box and contents when you poked the box with your fingers. I nearly had a heart attack when I first opened it up and saw the balled up newspaper. I felt better when I saw the inner box. After unwrapping, I was relieved as I thought this would be the first box I ever received that did not sustain shipping damage when cushioned with crushed paper products. This relief was short lived, however, when I saw a 2-3" crack running along the left upper corner of the case while operating it.
This makes for me a perfect 100% damage rate when paper cushioning materials was used in the packing, whether newspaper, brown paper packing, or expanded/perforated paper packing -- didn't matter. In this case, the damage was probably not worst only because it was bubble wrapped and double boxed. I paid an extra $20 and asked that it be packed well. Oh well, the saving grace is that it's so very nice cosmetically and I'm pretty sure the crack will be nearly invisible using some plastic solvent to "weld" it back together.
What type of failure or damage rates are you guys experiencing when a boombox arrives and paper packaging material in some form or manner is used? This is a POLL.
