Philips D8080 'Le Cube' Restoration - Pinch Roller and Battery Cover
Hi everyone,
A while back I bought a Philips D8080 (for images and info: http://www.radiomuseum.org/r/philips_voving_sound_d8080d808.html) with a few issues. The first and most important of these was that the tape player wouldn't work. The second was that the box is missing its battery cover.
The tape player only turned the tape for a split second before stopping completely. I thought it was reasonable to assume it was a slipping belt, so set to dismantling the box to have a look. It turns out that it was pretty difficult to navigate in there. I really get the impression that Philips didn't anticipate anyone attempting to service the D8080 - everything seems pretty awkward to get too and there were lots of plastic clips that felt ready to break whenever they were pulled apart or put back together, especially the deck itself, which I couldn't figure out how to get apart at all without breaking it.
So after taking it all apart, cleaning the case and finding that a colony of ants had made a home for themselves in the styrofoam around the drinks compartment, I found that the belt was fine, and that the play gear was missing a few teeth. Both the rewind and fast-forward gears were also missing teeth, however still worked. After researching the internet and finding that the Philips boxes of the era were a little notorious for this, and given that I couldn't figure out for the life of me how to get to the gear in question, I decided to put a blob of blu-tac where the missing gears were, which seems to have done the trick, at least for now.
As this is my first restoration (and my first cassette deck since I was about 8), it was only after doing this and putting the box back together that I noticed another now obvious issue with this deck. I tested a tape only to find that the tape was running stupidly fast and the speed was fluttering all over the place. After a bit of research I found that this may result from a worn out pinch roller, so after finding out what a pinch roller actually was, went to check on my machine only to find it was missing it all together. I've attached an image where you can see this.
So my question here is if anyone knows what sized pinch rollers a D8080 takes? I've got my eye on a 13 mm diameter one on ebay, which from what I can see seems fairly standard. This one also has a built in axle, which suits me as I'm missing that too. Any help here would be great.
My other question is whether a fellow D8080 owner would be kind enough to send some detailed image of the battery cover. I'm hoping to replicate it in some way. I'm not sure how yet, but my brother has access to a 3d printer, so that might be an option.
Thanks for reading my rather lengthy first post, and any help you can provide will be greatly appreciated.
Zippy
Hi there,
and first of all: welcome! :yes:
I own a couple of these actually! And I have taken one apart once, too. Only for a paint job, though, not for repairs. I can try to check the pinch roller for you. Concerning the battery cover: what colour is your LeCube? Is it the white or the yellow version? I have a white one (with issues) which I'd sell for a low price (like 10€ + shipping). Might be worth it depending on your location. Definitely less expensive than 3d printing and a better result, too.
Thanks Zippy,
I have a white one, however live in Australia, so it wouldn't be practical for shipping. Thanks for the offer though. I'm more interested in just having something to cover the hole to neaten up the appearance. There's something in the manual about the battery cover sliding into positions depending on what power source you want to use. I'm not sure sure what that's all about, so thought it best to see if I could get some pictures to try and figure it all out.
It would be great if you check the pinch roller size etc. I'm at a bit of a loss at what to do at the moment.
Man, he's offering you a complete unit for 10 euros + shipping! Just do it - it's the right colour and you'll have all the spares you'll ever need! You've got to have a proper battery cover!
I agree it's a very generous offer. I've just had a look into the estimated postage costs and it looks like the cost of the unit plus postage would be a good deal, much better than I can get locally (except for another box that also has a missing battery cover), but at this stage I'm more interested in making the most of what I've got rather than having parts boxes etc.
So while I completely understand your attitude Jimmy, and I am very grateful to Zippy for his offer, I just don't feel that I want a second box.
Zippy
I can totally see your point. Gathering and storing parts units can be pretty tiresome. Comes time, comes the right part ;-)
Here's pictures of the battery cover. You'll probably get the idea once you see it.
Thanks Zippy. That makes perfect sense.
I like your Meloncube, and I agree that the LeCube lends itself to customisation, as it's too much of a novelty to really get precious about. I'm surprised they didn't make them in a bigger range of colours, as it looks great in yellow and, as it turns out, green and red. I do like the white though, as it reminds me of the original Gameboy colour scheme. Unfortunately the plastic on mine has gone a little beige, and some of the coloured plastics are a little faded. Not enough to get too worked up about though.
I agree with you that the bass in a bit lacking in these boxes, and new speakers are something I had in the back of my mind for the long term, after I've got everything else working. The current ones are a bit tinny.
