Arrrived by courier today via a slightly cheeky bid on eBay :
A great condition Aiwa 950 (K)
I first bought on brand new as a present to myself when I landed my first full time job - I think I bought it from Currys (U.K. electrical store) but it may have been called something different back then.
This was my first and only boombox and was an upgrade from a good liitle Aiwa mono Radio/Cassette player I used to tape the "Top Forty " with from the radio.
I can vaguely remember auditioning 4 or 5 alternatives including a massive Sharp but decided on this one as the sound quality was great,it only needed six batteries and Aiwa had a good reputation at the time for tape decks. Also it was slightly cheaper than the Sharp and easier to carry around -also a friend had had reliability problems with his cheaper model Sharp.
I was a bit nervous upon unboxing as the seller had siad they had no cassettes to try in the deck but they stated there was movement when they pressed the play key.
I was relieved to find that the tape plays great after a little clean of the heads.
The cue/review function is fine, both aerials intact and dial backlight works-as do the VU meters so I`m well pleased.
Only fault found is the tape counter belt seems to have gone -so most likely to be found as either a small pile of goo or hopefully just a broken belt when it comes to an inspection.
I have a few questions that I hope someone will be able to help me with regarding the inputs -I`ve attached some pics.
Can anyone tell me what the name is for the bottom pair of outputs for external speakers is please?
I think the top pair were known as DIN sockets but I`m not sure and other than the tape I have no idea of what the other symbols signify.
Am I right in thinking that I should use the top (tape) input if I`m trying to find a lead to connect up an MP3 player ?
I won`t be connecting to external speakers but just curious about the sockets.
Some of the other versions of this model had the more straightforward phono connections but I expect this was a model for the behind the times Brits ! :0)
Thanks in advance for any info.
Have to get back on eBay now to seek out a load of cassettes !
