Hello
I need your help to complete a restoration of a SHARP VZ-3000.
On a speaker SHARP CP-3000, only the tweeter works, the woofer does not give sound. Same situation whether it's on the right or left exits. I control the voltage at the terminals, everything is ok.
On the service scheme, a coil is on the circuit. L1 0.6Mh. How do you control it?
Or another solution to advise me?
Thank you
Thank you
