need belt sizes for rising src 2015
aus10whales
hello, i have recently overhauled my rising src 2015 and its all working but the belts definitely need to be replaced. it is slow to start playing and wont play some tapes that are more heavily used. fast forward and rewind work perfectly no matter which tape so i’ll take it that the tire for the take up reels is fine. i’ve been searching all over online and can’t figure out what belts this takes. looks super easy to replace but just not sure which ones it needs. i’d rather not use those cheap generic belts that usually cause worse wow and flutter.
any help is appreciated!
If I remember correctly, the Rising needs two square belts 5" and one flat belt 9". As for thickness, I'm not sure. I would go "small" on the square belts and "medium" width for the flat.
Reactions: aus10whales
