need belt info for Aiwa HS-P02
ahardb0dy
Took my Old Aiwa walkman apart and it needs belts, can't figure out which ones to get. I can tell you all that the belts from Aiwa walkmans are just as nasty as the ones from their boomboxes. I must have used about 50 of those single ended long cotton swabs getting all that goo off!!
AO
Tempted to suggest you take a look at your old belt, it is square section or round. It's difficult to say exactly what size but you cn buy packs of various sizes on eBay for round or square.
monchito
tony i use windex to clean most of that belt goo the belt you would have to do a try and error if you have some used one from a another box see how it fits as long its the right one because some of those walkman use the square ones and some the flat ones :-)
