Hey boombox bastiges!!
What's crackin? I decided to tackle another legend of the 14" & higher club....The mighty RX-A2 is a loud powerhouse of a blaster that can burn through 10 D-Cell(s) in about 20 minutes. Some swear they get a solid 30 watts a side even though it rates at 15 per side RMS I believe.
The only drawback is the woofers that favor raw SPL's(volume) at the cost of bass & warmth or what some call presence. I wanted to fix that, same as I did on the RX-A5 which I tend to think is a success & another sleeper power-hammer waiting for the right speakers.
So I bought these goldwood premium woofers & tried to fit them in & they just barely squeeze into the tight cabinets by literally 1mm. I still have the originals in perfect condition too. Check out the difference between the 2...
https://www.youtube.com/watch?v=eccGht1Un_8
The new woofers are very efficient, 90db/1w/1m/1KHz & the unit is still very loud, very powerful & sounds very good now. The only glitch is that when listening at low volume I get a hissing scratchy noise in the left channel but when you press play, RR or FF, it goes away completely. If you have loud music, it goes away completely....
The plastic shell is nice and thick, but would sound better with proper fill & sealing.
