Hello kids. Watcha doin'? Well, I'm here to tell you I've acheived good bass from the GF-777Z & in that endeavour I've broken the 3 ohm barrier & loaded BOSE subwoofers from a Cadillac that have a DC resistance of 2.1 OHMS. Typically, under normal conditions, this would roughly translate into about 2.5 ohm nominal impedance.
I've talked to many knowledgable people about running the GF at 2 ohms on the super woofer amps & ALL of them cautioned me that the Hitachi IC's will blow if I put too much load on them, like say, 2 OHM woofers.
So I looked up the Hitachi PDF for the HA 1392 & I found some interesting things. As yo can see in the snapshot below, the spec shows 2 ohm operation at the bottom limit which implies it can run at 2 ohms. :
The max voltage input is 20v DC & the max peak current output is max. 4A which translates to a few more watts @ 2 ohms. Also, the spec mentions thermal protections so ultimately, if the experiment goes awry, the thermal trip should help me stay out of trouble. Ok, so taking that info into account & looking at the physical circiuts of the GF-777Z:
You can see the massive size of those sinks to wick away heat, compared to the size of the IC's & that is also a BIG plus for taking on this experiment & that is why I decided to risk the farm on a bet that it would sound good with the 2 OHM BOSE woofers. I also took into account that BOSE usually makes a well behaved transducer that is not hard on the amp's damping factor so the load to the transistors won't be that gruesome, either. The old subs I used were too current happy on the absolute bottom octaves.
Here's a few pics of the woofers in their new homes as 'Super-Woofers' in my GF-Dirty-DISCO-Destroyer:
