Hey guys just got my M70 all back together and working again 100% after pulling it all apart and cleaning everything up, picked it up last week and it had been sitting around for a long time im guessing, the amount of dirt and grime and dust that was build up on it and inside it was crazy. body wise it was in very good nick though, not too many scratches, damaged areas and i think it came out looking pretty good, was abit nervous having never pulled a box apart to this extent before but after taking lots of pictures and labelling screws etc so i knew where everything belonged it ended up looking a treat! even got it to work on batteries and fixed some static issues i was having through the speakers, now it sounds fantastic! also repainted the woofer grilles and chrome surround bolts.
just have a couple questions, it was missing the top 3 bolts that run along the top of the back case and i can't figure out what length they should be, can anyone show me what kind of screws they should be? also how do you tighten the antenna posts as they are too loose and swivel everywhere. the original antennas where broken so i pinched some similar off a crappy box i had lying around, they aren't perfect but do the job.
only thing i need to do is glue the label strip with all the tape names etc on and have to find a battery cover.
heres some before and after pics
also made a quick little video, qualtiy isn't the best though!
http://youtu.be/fl4sHUPT4SA
BEFORE
AFTER
BEFORE
AFTER
