stynger007 said:
Kewl, just wondering ,The flashing and color changes are cool but is it possible to sequence the lights , similar to a disco lite box? There are kits for this? Nice work
Well, yeah. I have a few threads showing the functionality of my various Mothership & Boom-Zilla RGB Mods.
You can purchase a raw kit which includes power bar, 5050 RGB LED strip, LED controller, remote control, for about 50 bucks shipped from Hong Kong in about 4 weeks....
You'll need additional materials for making your circuits & will have to modify the board to work with the blaster. If you do not know basic wiring & know how to safely tap into the fused DC voltage supply, then this is not for you. I have to warn members here that you should not attempt this modification unless you understand the risks involved with electrically modifying appliances & further, have a very well grounded understanding of curcuits, the importance of fused protection, etc.
Having said that, I have been making these RGB DISCO boxes for about 18 months, have completed 7 projects so far, am working on an 8th & ALL function just fine & without incident of any sort. The 2nd M70 Project has a total of 48 LEDs that runs simultaneously, depending on the settings & it runs just fine with the original power & fuse.
