Fatdog said:
Cool! All it needs is a handle and an input jack and you are ready to go.
What are the specs on the amp?
Bobby.
It has many inputs (USB, SD Card, guitar, microphone, Jack P2) and these are the front panel.
The amplifier has 04 Darlington TIP105 transistors, but I do not know what arrangement are mounted. (SuperDuper??)
It has a very loud but the soft dome tweetersI use realize some "grain" at high frequencies (maybe the THD of the amp is too high in the mid range frequencies)
Where I bought this amp, it was set up in PA Speakers in front of the store (with woofers of 18 "and plays well, but was not supplied with batteries (AC power used)
There are still some trim and a handle, I'm also checking the possibility of installing LED VU meter.
It is almost the same weight of a Fisher PH492.
Cheers.
