Modding a boombox for an iPod
mmcodomino
This might be an awesome project and a lot of fun too!
I would strongly recommend to use a flea find though because losing an expensive boombox for a failed project is not worth it!
And it it comes out good with the cheap one, you could probably go ahead and do it with a bigger one. :yes:
The instructions are not so good I think since every boombox is different. I would just go ahead and try my luck on the inside! :lol:
