I have a super scope box by marantz. The plexi dial glass is detached and it looks like it was originally affixed with some kind of brushed on adhesive. What do you guys use or prefer?
I've used this 3M weatherstrip adhesive with great success in the past.
Just be careful with it though,it can get a bit messy.
It comes in clear and black,I use the clear.
Most auto supply shops carry it.
The description on that says it bonds to metal and rubber:
"Strong, flexible adhesive bonds to rubber and metal.
Resists vibrations, water, oil and grease.
Temperature range is -20° to 300°F.
Yellow neoprene adhesive."
But when putting on a tuner dial lens cover aren't you trying to bond plastic to plastic?
