Does anyone know if the same gears are also used in the cheap/low end BB's made by Magnavox/Philips? A free or low cost beat up box might prove to be a worthwhile donor box.
Are they the oem off like 7140/7240? If so I'd like one
Yes he still sells them on eBay. I bought another one but issue with them is they are a tiny bit smaller, probably from drying process. So they work but make noise and also autostop don't work cuz they are a little smaller.
