Lasonic TRC-920 said:
Two Questions related to this subject
1 do you blow out the area being cleaned after the cleaning solution has been applied to the switch, pot or slider with compressed air?
2 do you have to apply a lubricant to a switch, pot or slider after cleaning?
(1) Depends on the situation. If the chassis was removed from the case, then for sure. If the chassis is still in the case, then no because blowing it will surely cause some of it to go onto the backside of the tuner glass, cassette door and other areas where it's not desirable for it will surely leave a film and require complete disassembly to remove. Just use care, lots of rolled up paper towells to soak up excess and do not spray indiscriminately. Finally, use some good old common sense and anticipate before acting. Always shroud the tuner area before spraying, especially near the varicaps, and anywhere where there is wax. Believe it or not, the wax is there for good reason. Those areas are extremely sensitive to capacitance changes and the wax is used to "set" the components in position to prevent any movement. Yes, movement of the components can possibly change the capacitance response of those areas and the resonance of those tuned circuits. Likewise, introducing a film to that area could also change the capacitance.
(2) Deoxit already has some lubricant in it and additional lubrication is not necessary for the feelers/contacts to slide across the resistor board. However, if in doubt, you can add some Caig faderlube. However, I find that the controls feels quite grabby and not at all smooth after faderlube application. The proper way to relube the controls is to disassemble them, clean them by hand, then reapply silicone grease to shafts of rotary controls and along the edges of the slide on sliders. DO NOT apply grease on the resistor board or the control will no longer work. Don't bother testing out this theory because I already did. Although disassembly of controls may sound rather extreme -- this is the only way to restore that like-new feeling to the controls. The problem is that many folks flood the controls with contact cleaner and end up stripping all the grease from the sliding/rotating surfaces. The trick is to use only a teeny bit to clean the resistor and feelers and no so much to cause the grease to run off the rest of the control.
