We've been getting lots of new members asking about these particular problems with there boomers. I've done search and couldn't find any thread so I've decided to make thread so they can do search and find answer
1. Buy can of deoxit or a contact switch cleaner.
2. Take boombox apart and take plenty of pictures to remember how you've done so.
3. Sometimes you have to remove frame or other parts to get to switches and/or pots.
4. With straw on can put into small hole on switches/pots
5. Spray small amount into hole trying not to spray excess amount in or around area.
6. Work switch/pot each direction 20-30 times.
7. Wipe excess cleaner and let dry 10 minutes.
8. Before closing box up...test it..
9. If problems persist try once again spraying cleaner into problem switch/pot and follow same directions.
10. If problem is fixed put back together using pics you took.
Remember this is only a solution to alleviate problem switches/pots. It's always best to take them completely apart to clean them fully. But if your not tech savvy this is best solution, but same problem may arise down road.
P.S. while box is apart you may also want to clean box and deck parts and replace belts!!!
