Like many of the Lasonic TRC 9XX models, the antenna clips on my TRC-935 were busted off. The worst part is, the antenna's swing wildly when you walk with the radio. I have, (i'm sure like many have) used electrical tape to hold them in place. The problem with that is, if you want to use the antenna's, you have to fool around with the tape.
So, I decided to come up with a permanent solution.
I made new spring clips out of stainless steel sheet metal.
First, I started by preparing the old mounts....
I ground them down with a dremill tool....
Next was to cut small strips, The fuse is there to show size...
Next, bend the shape needed and drill two holes in each....
Two screws and a dab of hot glue gun to seal them and guarantee no rattles....
THERE, working antenna clips
