LASONIC TRC 931 GHETTOBLASTER FUNCTION SELECTOR GEAR BOX ON
BARTELL
LASONIC TRC 931 GHETTOBLASTER FUNCTION SELECTOR GEAR BOX ON CIRCUIT BOARD
The shaft goes into this metal box on the board and has a plastic gear on it. The gear broke. Any suggestions?
monchito
well all i have heard of is just finding the funtion switch and replacing it ,, i belive whatever company was used to make the switch was not a good one as it breaks very often on other lasonics to like the 920 i have then the real pain is trying to get that switch which is not made anymore :annoyed: so really you will have to hunt down a parts box or if someone has it for sale then jump on it quick :yes: :yes: :yes: :yes: :yes:
BARTELL
Yeah,
If thats the case then I may just sell mine. Its stuck on tape function but works fine. Id rather get $200 - $400 for it rather than put $100 or more into it.
