Hello all, Just joined in hope of getting info regarding a boombox i have purchased recently,
Deck 1 played for a couple mins then stopped, I opened it up and can see compared to Deck 2 that there is now a small band missing so i think this perished as soon as i used it after purchasing on ebay.
This band is a shorter one of the two, So there is a Longer one that connects to a big metal wheel which Both Decks uses, But the one broken is the small one which sits on 2 small wheels behind and between the two wheels that come into the cassette to turn it, Also it is the one from checking working Deck 2 which turns all the little plastic cogs you can see in the centre of the deck..
On Deck 2 i can see there is a band on the same wheels as the Deck 1 which is missing one.
I feel confident that i could replace this myself but cannot find any info on internet for which length i would need.
I Hope i have explained myself well enough, The system is a JVC PC-W100
I have actually took a chance and ordered a set of mixed bands from ebay which vary between 40-130mm, but totally happy to rebuy if these sizes are not useable
