You are correct, but it doesn't matter. There are 2 more DIN pins.blu_fuz said:I see that the pin count in the connectors aren't the same and physically would not connect to the main board the way you would want......
M70L. Yes the RIAA curve circuit is one way to go. Quite simple to DIY. http://www.epanorama.net/circuits/phono.htmlHisrudeness said:That's an LB model? You can use an antennuator and it will work just fine. It will save butchering a mint one.
This can't be done without attenuator circuit because din signal is very low compared to line level. As you can see it on the schematics above, there is one extra amp for din input on 70L models. I think maybe bypassing it to get line level input, but then there is that REC button combo to activate it.k2j said:am i missing something or couldn't you just buy a din to rca cable?
Yes I am, thanks for being helpful.im_alan_partridge said:I have the same model and, As Rudy said, mine works fine with an external attenuator
In case you are not familiar with an attenuator, I will have a hunt for some pics I have posted on here of mine.
This seems the most logical way to go.ABSOLUTELY! Beautiful! Wow!stosoorok said:I got a dilemma. I just got mint condition M70L. Not a scratch on it. It has 5pin DIN and phono-in. No input for today's tech. I'm thinking of a BT or regular Line-in and ditch the phono/din amp inside. What would you do? To modify or leave it as is?
20150930_185024.jpg![]()
