JVC M70 Antenna
valjo
Hi!
I am looking for one original antenna for JVC M70, or set of two non original but close match Antennas for JVC M70
BR
Transistorized
I found this to be interesting if you can live with non original but functional. I found this post and did a search for the RCA style antennas mentioned. They should work as long as you have the slotted rotating barrel base. It would be a cheap aftermarket option.
Have a look at this thread: https://www.boomboxery.com/forum/threads/was-looking-for-m70-antennas.23704/
There is an original pair right now on ePay but they want 70 USD with 50 USD in shipping and that is insane.
Reactions: valjo
valjo
I am aware of tihs option yes, but i prefere original. thanks anyway ‍
Well i have just bought jvc 656, according to informations it has same antennas as m70.
At the end i will have m70 with original antennas, and i will source some non originals for 656.
valjo
Transistorized
My pleasure. You had originally mentioned you were open to a set of non-original close match options. I think the RCA ones in that post are a bit longer. Original is always best for sure. :yes: As you mentioned, quite a few models share that same antenna size.
valjo
That is right. I just hope that m70 and 656 has same antennas (as mention on forum) :)
