JVC DC-7 battery Box and Sound qulaity VS JVC DC-33
prg333
Hello
Does JVC DC-33 NEEDS that little removable battery box to be able to be used with 10 D cells. Naturally if missing from the radio it can't be played on batteries.
Also haw much does the JVC DC-7 weigh and how does it sound overall? Good bass? Nice rich full sound? I assume the JVC RC-M70 sounds BETTER then the DC-7..
Also how much does the JVC DC-33 weigh in at. Just "won" a DC-33 on Ebay for $51.00. Tape deck belts needs replacement BUT the Turntable reportedly works. DC-7 a BACK-BREAKER but hopefully the DC-33 is lighter.
BENDYCAT
:lol: :lol: :lol: :thumbsup:
Have a dc7 - sorry just gave it away !
m70 is better than both put together x10
the DC7 is very heavy indeed - close to v2000 weight
the dc7 has a good clear sound that can go up loud - but not much in bass (it would shake the record too much)
DC33 write up
Portable Stereo Center. Built-in 23 cm deep turntable that can play 30 cm LPs. Slide-out turntable. 5-band equalizer. Cassette recorder with ANRS/Dolby noise reduction. Music Scan. FM stereo, LW, MW and SW bands. Output 2x12 watts. Microphone mixing. Detachable speakers. Power supply: 110-240 volt, 50/60 cycles. 8 batteries , optional battery pack or via car battery adaptor,se accessories). WxHxD: 73 x 35 x 24 cm. Weight: 16.6 kg. Batteries not included
DC7 write up
portable stereo center, with turntable as well. With a 23 cm deep turntable unit that can play 30 cm LPs. Presss the smoked acryl door lightly and the turntable will gilde out. Linear tracking arm system with automatic record size selection. Receiver with automatic source selector, microphone mixing and an output power of 2 x 20 Watts music power, 4 bands: FM stereo, MW, LW and SW. Cassette recorder section with Music Scan for easy song location, REC mute button, automatic recording level circuit, soft touch operation, timer function and metal tape capability. Detachable 2-way bass reflex speakers with a powerful 12 cm bass unit. 4-way power supply: AC power 110-240 v, 50/60 cs, car battery connection via adaptor, rechargeable battery pack or 8 batteries , not included. W x H x D: 72.7 x 35 x 23.7 cm. Weight 16.6 kgs
bad boy M70
not best condition panny
you could always go for one of these :thumbsup:
Reactions: AlexFedy
prg333
Thank you for the information on both the DC-33 and DC-7. Looks like the Dc-33 is no lighter then the DC-7. . Not quite as large in size
prg333
Thank you for the info on the DC- 7 and DC-33. Does the DC-7 have a battery box that you need to operate with batteries? Or is that only one the DC-33
:drool:
the dc 7 has a battery compartment built into the back of the speakers you just remove the black plastic cover from the speaker with a flat head screwdriver and the batteries go in there ,it had power leads to run along with the speaker wires that plugs into the back of the unit.
