Is there a way to increase the output from the speakers on boomboxes. I just picked up another VZ2000 and this doesn't sound as loud as the first one i got. Having said that, i reckon the second one sounds better, the first sounds as the volume is to high at the same setting, (a bit like a cheap stereo and crappy speakers that are playing at max)......especially if you go to around to 6 on the dial. The guy i got the first one off did have it stripped and he said he soldered up a couple of dry joints, and Ive noticed that the left speaker is slight louder than the right. I can remember years ago taking a cassette player apart, there was a several small screw like posts that you could turn, but i didn't know what it adjusted......is there something like that on a boombox circuit board???
Kev
Kev
