So when I hit play for a few seconds the highs are nice then they just plop and all you hear are lows.. Any ideas I'm thinking maybe a bad cap :-(. I've already cleaned and demagnetized head plus my second deck sounds perfect
BoomboxLover48 said:It looks like the motor is hesitating to take load.
It could be due to problem with the commutator/brush or there is a wheel or bearing in the transport giving some frictional resisatnce.
Cpl-Chronic said:Have you played around with the alignment screw for the tape head yet? My 8989 I sold to Jorge89 did the same thing & I adjusted the alignment screw until it sounded right & after that all was good & sounding great. Too bad I borked the cassette trying to fix the record feature.
baddboybill said:Ok it was Azimuth. Usually this only causes problems on one channel but I'm back in business. Thanks guys
baddboybill said:Well it's fully fixed its better but I think it's bad cap like I originally posted. :-(
BoomboxLover48 said:Bill, Do you see any depression from wear If you look on the head surface where the tape glides?
Try another tape. Sometimes the pressure pad under the tape goes bad and don't give a good contact.
Cpl-Chronic said:no problem. Keep us posted as to whether it was a permanent fix or not. After playing with mine, tapes worked great for good after that & mine had the same behavior before I played with it so hopefully, it solves it for good. nice CEC btw. I saw 1 with both decks working sell for almost 200 on the bay, just recently.
Keep it boomin'
Cpl
baddboybill said:BoomboxLover48 said:Bill, Do you see any depression from wear If you look on the head surface where the tape glides?
Head is clean, actually super clean especially since its cheaper unit but it is up top which is better than at bottom. Could be tapes too but I just played one side and no issues. So hopefully she's ok
baddboybill said:Nope tried 3 tapes and plays fine now
