MesaAZGuy said:
Thanks! Theres a JVC 838 radio on ebay for $299 but it needs some work. Mostly cosmetic. Not sure if I can do cosmetic or find trim pieces for it.
Funny, most of my work on boomboxes to this point has been fixing up 838s. I'd consider the fact that the cosmetic work is probably the hardest. The metal faceplates on the top and front are thin, are almost always a bit scratched and dented, and aren't easy to remove without damaging further. I don't mind living with some history though. Just realize that it's not easy to fix these cosmetic issues. Sounds like you can handle the mechanical issues.
The 838 is probably my favorite boombox. It's so cool looking, it's well built with more metal and less plastic, it sounds great, it gets loud, it has a great tuner, and it has a solid aux for your phone. The only area where it's lacking is in the bass department. Boxes from the 70's just weren't ready for the bass of the eighties and nineties.
Good luck!
