I have what I hope is an easy question for you guys. A grille on my i931 got pushed in and I need to repair it. I'm guessing it's easy to remove them. I just don't want to screw it up. What do I do? Thanks!
It should be a fairly simple task gettin open and fixin..... just a screwdriver needed....just remember to not over tighten the screws when you reassemble....don't wanna strip out or break those posts.
