Hitachi TRK-8130E - Rough Sounding/'Blown' Speakers?
MyOhMy
Hi, All.
My 2nd Hitachi TRK-8130E has speakers that sound very 'rough' and somewhat muffled. One speaker isn't too bad but the other one is quite bad. As a beginner, this is new to me and the only 'test' I could think of was to check/compare the sound through headphones. The TRK-8130E has an automatic speaker cut-off when headphones are plugged in. Listening through the headphones, the 'rough'/growly sound was exactly the same so I'm guessing that the problem lies somewhere 'pre-speaker'/'pre-headphones' in the sound output? Radio or tape, the sound is the same. Is there any further tests I can do or would this be a bit of an expensive fix, too technical a fix, unfixable/lost cause or am I way off the mark on this?
Any help would be very much appreciated.
try cleaning the headphone jack sometimes just spinning the phono plug in the socket helps also press play record stop repeatedly a few times on the tape deck to work the record bar back and forth.
