Hey guys,
A few might know me from my thread about the repair of my hissing Hitachi 3d7. Now that the problem is (hopefully) finally found, I can start with the 'modernization' of this boombox.
I know there already are many bluetooth built-in projects, but I've found none where one uses a module like this.
The module I'm using supports buttons (play/pause, vol up/next track and vol down/previous track), bluetooth calling and of course audio. For 9$, it's a steal.
Here is the link for those interested: http://www.ebay.fr/itm/371406194317?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I will update this thread each time I make progess.
If you got any ideas, feedback or even criticism, I would be happy to hear em !
PART 1: Reallocation of the tape deck buttons for bluetooth control.
I want it keep it as original as possible from the outside, so I won't drill any holes for the buttons (pictured here). I'll thus abandon these buttons altogether and use the tape deck buttons instead, which is way cooler too btw.
The buttons shipped with the module have one common ground, and each has a separate cable. When a button is pressed, it closes the circuit between ground and it's cable.
The 'play', 'rewind' and 'forward' tape deck buttons will be reallocated.
Here are some pictures, I think they are quite self-explanatory:
This is the common ground, for this I used some screws and a piece of copper from electrical wire. This will be soldered to the scews, I hope that this will hold well
I then hot glued the wires on the switches, those will make contact with the ground when a switch is pressed (at least I hope so ).
The new wires will be soldered to the wires that are now connected to the buttons that came with the module.
This will be updated soon !
Greetings,
inse
Greetings,
inse
