help with rising 20/20 speakers
Please bear in mind that the OG speakers are something like Sensitivity (dB) 95db rated so only buy speakers that quote and match as close as possible to this rating.
Reactions: ElectricDevil
ElectricDevil
Thanks for the help,ill go with a set of the ones you mentioned..what about for the tweeters?
And will watts be in issue being the woofers you recommeded are 260 watts?
The rating on the watts is always overstated you only need 10watts. You want some tweeters that pick up at 5k theses are not so crucial on the quality.
