Just scored a Holy Grail! Near mint M90! Everything works great so far except it needs a new belt and the FM is touchy.
The biggest problem is with the Line in. It wont play in Stereo. Only the left side works. When I switch it to mono I get mono sound from both speakers, but in stereo only the left side. I tried touching the 3.5 jack with my finger and still only get a buz from the left side, the right is silent.
The tuner and tape both play in stereo fine.
Is this something some deoxit might fix?
Or would I be able to replace the line in pre-amp with one from another model donor boombox?
Any suggestions or solutions would be greatly appreciated. Thanks!
You can also try to flip switch back n forth a bunch of times to see if that clears it.
