Help in Hershey PA
pabaker
Just wondering if anyone is close to Hershey PA and wants to help me restore a Helix hx-4634 :). I am competent and a quick learner. Thanks.
Smeats
Haha sorry pabaker couldn't resist,I'm sure Hershey is great! I just looked up Helix 4643 and it's a very nice looking box totally worthy of a restoration. I'm a bit far away to lend a hand ✋ but good luck buddy!
Pabaker, Please list the issues with it and most members are very familiar with this box and how to fix it. Some issues are easy to fix and others are hard depending on the nature of the problem. [SIZE=4.5pt][/SIZE]
From what I know it is not an easy box to take it apart.[SIZE=4.5pt][/SIZE]
You need to label lots of connectors and wires properly and take lots of pictures as you go through dismantling and reconnecting parts together. [SIZE=4.5pt][/SIZE]
Decks are problematic and not well made. There are lots of members who had done all kinds of work on this box. [SIZE=4.5pt][/SIZE]
Once you describe your problem they will be able to walk you through it. [SIZE=4.5pt][/SIZE]
Good luck![SIZE=4.5pt][/SIZE]
