HI,
Almost all the stations at Medium Wave bands on ANY tuner at my home produces a unbearable noise and makes them unhearable. Only noise can be heard. I dissconected the boombox from mains power supply and get it worked on battery. Noise still persists, the same. However, when there is an electricity failure in our locality, battery operated tuners still gives the noise but at slightly suppressed level. This strange behaviour is true to every tuner at my place irrespective of the model or brand. Also, the same tuner works just fine when i took it away some kilometers far from my place (including MW bands). Only the Medium Wave stations are creating problem. FM and all the Short Wave bands works, just fine. I am very upset about this, because i have shifted to my new house and want to build my own working lab for my electronic experiments and projects. I am sad to believe that none of the tuner will work here on MW bands at my new place. I am sure this is not the electrical power induced noise. Is there a remedy possible? Is there a way or a tool or some circuit design to rectify this at my place here? Why only with all the Medium Wave Bands?
Thanks!
Thanks!
