I was going to try to fix a 37" Magnavox LCD for a friend of mine thinking that the capacitors on the power supply board were bad, but that doesn't seem to be the case and now I am lost for answers..... If I can't fix it they said to put it on epay for parts.
So basically, the sound and picture work great! BUT, the picture eventually gets dark blobs showing up in random places. Then once in awhile there is a square shape that is about 2"x2" floating around in different spots
Not sure what to do next, capacitors are ok, if you have any ideas go ahead and throw them my way. I am thinking either the circuits are heating up too much (because some heat sincs are too hot to touch), or there are poor solder joints that are causing problems, or???
Good picture (will play for over an hour sometimes before the blotches show up):
Then the dark blotches show up but picture is still visible on other parts of the screen and sound is not effected:
Here are some pics of inside the back:
These heat sincs get reaaaaaaally hot on the power supply board:
.Not sure what to do next, capacitors are ok, if you have any ideas go ahead and throw them my way. I am thinking either the circuits are heating up too much (because some heat sincs are too hot to touch), or there are poor solder joints that are causing problems, or???
:annoyed:
