Says only 1 channel works. Where should I start. Going to attempt a fix and clean up to sell for a friend What I put into it. Needs a tuner knob as well.
I've worked on 2 of these already & there are 2 plugs that connect the speakers tot the amp out & each plug has both left & right channels for the speakers. On 1 of mine the connector was loose fitting & the left channel would cut in & out on the outer woofers. If 1 channel is gone on both inner & outer speakers, it can't be a connector. When you open it up try wiggling the connectors but be careful while you have live juice running through it. It could also be a shorted voicecoil in 1 speaker that is shunting the signal & preventing the channel from working.
