Hi all
Sorry if I'm posting in the wrong forum.
Back in 198? I bought a Sharp GF 555 "The Searcher" brand new from Huddersfield Hi-Fi Centre, Cross Church Street. I seem to think it was c.£170 and I'm annoyed that I found the original invoice last year then threw it out!
Several years ago, as it had not been used for ages, I decided to throw it out but saw they were fetching £85 on ebay so put it back in the cupboard thinking my one careful owner from new 555 must be worth something. Having been meaning to do something with it for years I finally took it out of the cupboard last month to give her a whirl. I'll confess that I'm trying to get it working to sell it as it seems too good for spares or the skip.
The radio (original undamaged aerials) works on all 4 bandwidths
One cassette played ok but the other started to chew the tape - research suggested that rubber drive tyre had turned to black mush and it had. Having found some excellent videos on YouTube I took it to bits, cleaned out the gunk (from both decks) and fitted some silicone tube I'd bought and reassembled. I thought I'd fixed it as the cassette played but when I tried to rewind it would not budge and when I removed the cassette to turn by hand it was very stiff. It turns out the tube I'd used (2mm id 6mm od) was slightly too large and not allowing the necessary 'slip' that is needed to account for the take up reel going from small to large. It was pulling the tape past the capstan hence being tight on the reel. I swapped this tube for some sleeving from plasticised garden tie wire. It worked but I don't know how durable it will be so if anyone can advise where to buy something better (surely it can't just be available from Australia) I might swap them (again)
Despite the years the belts seem in good condition and the fast forward and reverse works on both decks as does the auto-stop on both fast and play. I saw the post with the cross references but does anyone know where I can buy replacements in the UK?
Power switch - does not work but I don't think this can be fixed?
Sliders - some crackling. I've got some electrical contact spray bought for something else; can this be used and is it a case of spraying some where the slider arm goes in to the pot?
Sound balance - using either cassette, line-in and phono the left speaker is quieter than the right (swapping Left and Right input cables makes no difference). It's also reflected in the VU meter lights e.g. if the RH lights are solid on the LH green will be solid and the red flickering (hope that makes sense). I've driven myself mad trying to tell whether there's a difference with the radio and I think there is.
I'm also not 100% sure whether it's a pure volume issue or whether the tone is different e.g. a tad bass light.
I was going to try some resistance checks on the speakers but as they are soldered I cannot test them individually.
I'm a bit stumped with this - any suggestions?
And thanks for sticking with me until the end!
