GF-515 L/R channel volume diagnosis
Scotty_M
Sharp GF-515.
Sprayed all switches, headphone jack etc etc
Radio - Volume only through the right channel.
Balance control - Set all the way to the left i can hear faint sound through the left channel (this volume doesn't change when turning up the volume knob either). When i adjust it away from full left i can hear the right channel coming in even though i'm not back to the centre balance position. Before I reach centre position the right channel is at full volume...and adjusting it to the far right maintains the same volume level from the right channel.
Radio playback through headphone jack - The balance control behaves just as described above except when on centre balance position and i wriggle the headphone jack connection, i hear equal volumes from left and right channels. But if i remove the headphones from the jack, i revert to the same problem.
Any general ideas on where the problem is would be appreciated.
Scotty
