Hello,
I just started getting into actually opening up some of these old boxes in order to fix them.
The fear is slowly fading away. Right now im working on Panasonic RX-CT900. I got the main console working ok and both tape decks are good to go,
but I need some help with identifying some foam inside the speaker enclosures. the actual driver needs to be refoamed which I think i can handle but there is a layer of foam that is behind the driver that I want to replace because its old and crumbling. I have attached a photo for reference.
What is this foam called? where is the best place to get it?
Any advice/help would be greatly appreciated!
S.
S.
