when i think of the name sankei i usually think of big cheap boxes with all kinds of wierd bells and whistles. i mean i seem to remember one of there offerings having a built in drum mahcine back in the eighties.
well after todays find i have come to think that maybe back way way back in the mid seventies sankei was putting out some pretty amazing boomboxes for the time frame.
after many months of finding nothing i went out on a whim and checked out the local value village. sure enough tucked aways on the lower shelf the chrome handle smiled at me from the corner of my eye. what i had thought was a marantz at first rapidly revealed itself as a old old old sankie trc1000 super stereo.
looks like they knicked a bunch of ideas from the old sony four speaker units or maybe it was the other way around i have no idea.
wow this six cel box is quite heavy and its build quality is extremely good. everything was intact dusty but all there i opened the battery cover of course value village almost always leaves the batteries in there merchandise. it kind of pisses me off because they really should remove old corroded batteries but for some reason they dont.
no power cord so i have to take this 15 dollar box on good faith
a little bit of a gamble but hey i figure it was worth it.
am fm and two short wave bands. i look at this box and right of the bat you can tell this was made to be serviced. again it is quite heavy i cannot recall having a six cel boombox that wieghs this much.
two condenser mics nice meters for levels and tuning. fm stereo light. a very long proper antenna.
i could take of leave the grills on the box . side firing speakers .http://img836.imageshack.us/img836/1084/f8
i arrive home give it the old clean up wipe wipe wipe wipe.
find a plug for it after getting rid of most of the rust from the battery tray.
the moment of truth.
power up push a couple of buttons and wow the room is filled with nice warm detailed sound. all the knobs and buttons work. no static.
will the tape player work.
sure enough it does. this really shocks me because i cannot think of many units with a thirty three year old belt that just work with no servicing needed.
i dig around a bit and find the original add for the unit online. wow 300 dollars 1977 dollars for this radio mrsp. even if you did get it for 250 dollars it would still be a massive chunk of change.
the box plays very loud much louder than you would expect for a 6 cel boombox. i think it must have something to do with the kind of transformer being used in this boombox.
well you can take of leave the looks i guess. i like it and i am extremely impressed as i say with the quality of construction and the sound of the unit.
is it my favorite boombox i of course not.
i do think tho if you have a chance to get one of these for cheapish you should jump at it. i mean it is no cheapo made wanna be sony box its a really high end portable radio from the early boombox era.
nope its not a m90 or a m70 and there is lots of beefierboxes but this is one nice radio. i am just posting a photo of the add but you get the idea.
[img]http://img836.imageshack.us/img836/1084/f88b09c5ee58b5e58acbcb0.png
