http://www.ebay.com/itm/RARE-CUSTOM-RED ... 43b2d3d8ea
Poor guy ....HESITANT TO EVEN SELL IT... :gathering:
Yep, found that out the hard way after taking a beater car to Earl Sheib.....jimmyjimmy19702010 said:The orange peel paint job looks even worse since he used clear coats to show up the paint faults - yuk![]()
Superduper said:I wouldn't mind owning that... looks pretty good to me, although like someone else says, it doesn't really match in the backside. Perhaps the back done in black or charcoal would look more appealing.
Electric blue metallic !!!!! Or have the casing chromed.gsbadbmr said:Since I have a few C-100's, this winter I am going to try something with 1 of them.
Does a few = 100?gsbadbmr said:Since I have a few C-100's,
hemiguy2006 said:Electric blue metallic !!!!! Or have the casing chromed.gsbadbmr said:Since I have a few C-100's, this winter I am going to try something with 1 of them.
Reli said:Does a few = 100?gsbadbmr said:Since I have a few C-100's,
It does according to eagle eyes!![]()
Sand it down and do it again dude.
JustCruisin said:If you are going to paint a box, do it right! Remove the faceplate so all the little grooves around the rocker switches and knobs get painted, the cassette areas get painted, and the tweeter surround plates get painted...
THis just looks like a half-ass Wal-Mart spray can job!![]()
thatoldman said:Does anyone else have other than original colored boombox's, or just this ebayer?
