Corroded Battery terminals! Help!!!
Jboulukos
Hey, attached are the battery terminals of a unit I’m cleaning up. Any advice on cleaning these corroded terminals? I would like the unit to be able to function with batteries. Thank you in advance. 9C05B86B-AB3B-43D6-BBBF-559B49CA7A1C.jpegF410FDE1-705A-4C66-B9D2-85D65A8C5E6C.jpeg
You can get light rust / corrosion off with with sandpaper. Some use a paste made from water and baking soda to clean. I've also seen lemon juice used to clean corrosion. I would start with the baking soda paste and then go from there. Your terminals do not appear to be too bad.
Jboulukos
I did the baking soda paste and it worked very good. Much thanks!
Reactions: Bru87tr
Bru87tr
I haven’t seen too many people mention it, but magic eraser would prob work well too.
I used a dish scrubby once to clean a chrome piece and with some elbow grease it took all the corrosion off. Took a while but doesn’t leave behind any scratches. The kind that are sponge on one side and sand paper on the other but soft.
Reactions: Jboulukos
hmgway
Baking soda and water paste has been a trick for battery corrosion in the auto world for decades. Very cheap solution that's already available in most households.
I know baking soda removes green battery corrosion, but rust??
If you can pop the coils out, soak them in vinegar. Take a toothbrush to it occasionally to kick off loose chunks.
Depending on the amount of rust it will be 100% clean after about 2 to 5 days
Reactions: Superduper
