Cont'd ** DISCO ORTHROS II ReDUX ** Another 3 Headed DISCO Monster
Cpl-Chronic
Decided to re-do the :LED systems for the ORTHROS II. I wanted to incorporate 3 LED controllers for a meaner looking display. The Leds for the 2nd version of the ORTHROS did not have that kind of sinister look the 1st version had....
Here are the 2 side by side in videos for you to ckeck out..
1st ORTHROS(Traded to Vintage Man)
https://www.youtube.com/watch?v=CjNP1-kiHuU
2nd ORTHROS
https://www.youtube.com/watch?time_continue=2&v=uIs3zt3I2oM
So, after all that work, I felt that the 2nd version lacked a 'mean' look, almost cartoon like in the way the woofers & body lit up. too busy..so I went back to the drawing board & decided to re-work the sections & the patterns in which they lit up to try to bring a little more street cred. to the action
The result is kind of UFO like..
https://www.youtube.com/watch?v=H14BVF1Khoo
I still have the 3rd section to install so stay tuned.... :-D :weed:
Cpl-Chronic
OK....all buttoned up & ready to go:
https://www.youtube.com/watch?v=s5iXe1zPh_E&feature=youtu.be
pics coming soon....
Cpl
Cpl-Chronic
I had to crack it open 1 more time to fix a couple of small snags...
1.. the right VU was sticking @ the 1/2-way point & needed to be fixed.
2... the tape deck needed the head re-aligned so it could play tapes properly...
Now it's all fixed up & the deck is fully working, sounds good too...
Here it is playing a chrome tape recorded on a 3 head deck.... :yes: :jawdrop: :rock: :-D
https://www.youtube.com/watch?v=Hhu1WAE_CH0
As you can tell, the LED system is whisper quiet...no static at all...as always....
Cpl
Cpl
Wow man, these keep getting better. How many hours do you have into this one?
Cpl-Chronic
Thanx!! :-D Umm hard to say....probably about 60-80 hours between planning, fabbing the parts & connectors, etc. & installing, painting the woofer & tweeter areas, grills, testing, etc. Keeps me out of trouble....
Cpl
