Fatdog said:If the noise is coming throught the speakers, try this post:
http://www.boomboxery.com/forum/viewtop ... 128#p42128
Fatdog said:If it is not heard through the speakers, then it seems it is definitely a hardware issue. Maybe put a light coating of lithium grease on the around the hole where the flywheel shaft goes in. That's a usually a metal on metal spot.
steedums said:I'll give that a try. I have white lithium grease. Is that the same stuff?
