Brittle battery doors, fixable?
I am getting a battery door sent to me right now for my wheely. My original door was in good shape but when I went to push the tabs down to remove it, the tabs snapped like a saltine cracker. :-/ .
With my new door, is there any way to moisten up the plastic so it won't be so brittle where it needs to be flexible? Maybe I just had a dry door......
TRC-911
Don't worry about that ;-) I sent you a qualiy piece! The reasons these break are easy
1- The owner only pressed one tab and pulled/pryed it off
and
2-the owner put too much pressure on one tab and not enough on the other
or
3- they just got mad and broke it
lay a smooth think layer -- about 1/16 inch of "GOOP" on the inside of the tab --
---the side you cant see -
-that should give it some strength --
but -- nothing will make the plastic less brittle --
then --never force anything -
and never be in a hurry :cool:
TRC-911
I hope you know I wouldn't have offered it If it had a problem of any sort ;-) I hope it gets to you soon!!! I paid for priority :thumbsup:
I got it.... BUT I don't have my BBX to try it out :-(.... soon enough, soon enough. Thank you it looks great!
