Boombox eating tapes....
commodore
I got a Magnavox D8443 and it is eating the tapes. What's the problem? Solution? Does it need a new belt?
Thanks
monchito
more than likely or bad pinch roller rubber, a missing belt or something broken u might have to take apart just to see what is missing or broken or just plain good ole cleaning :yes: :yes: :yes:
Hello, it could be worn belts or possibly these are also known for worn out gears. Either way you will need to get inside to further investigate. But I will will worn you these are a difficult box to work on inside and if you decide to take lots of pics and write stuff down. Good luck :thumbsup:
