Best way to remove icky old belts?
mmcodomino
This is a problem I have stimbled across....I have seen that there are still many remains of the old belt on the drive.
How can I remove them without making everything sticky? :-/
100% isopropyl alcohol and lots of Q-tip swabs. For the depth / valley of the pulley's where Q-tips can't get to them, I use a length of thread and run it through the valley to absorb and wipe the isopropyl dissolved rubber.
As for not getting it all over the place -- you can't. It's a messy job no matter how you do it.
:agree: :agree: but it works :-D
mmcodomino
Thank you! :yes:
I just ordered a new belt and I am going to see hwo I can remove the remains of the old one safely ;-) .
skippy1969
Windex window cleaner with ammonia works great as well..... :yes:
The Ammonia really dissolves that sticky gunk very well....... :thumbsup:
45player
I have been using Ronson Lighter Fluid like for the old Zippo's, because the Naptha won't attack the plastic. I never thought Windex would work! I will try it, 'cause it's a whole lot safer. :cool:
skippy1969
Yes it works great Chris,and smells perty.........LOL!!!! :w00t: :w00t: :thumbsup: :thumbsup:
