I always like to know what the best way to clean the shiny dust caps.
We don't want to make the cone paper wet in the process of cleaning. These dust caps are like the cornea of our eyes, so sensitive. As you all know some dust caps are strong and some are very weak. It can be easily damaged with a very slight force in the wrong direction.
I pull the cotton swab tip, extend it a little more, and used a few drops of pledge cleaner. Then take a small cotton ball and gently glide over the surface barely touching it to shine it. It gave me good results with no haze and beautiful shine.
Recently at the end of the cleaning process, I tried Meguiar's Natural Shine Protectant Wipes, it gave the best results. I gently touched the moist wipes in the center and moved it to the edges without wetting the cone paper. Later, I used microfiber cloth to shine it. I make the soft extended part with microfiber cloth to gently shine it. It worked so well! This method gave excellent clarity with no haze.
Meguiar's Natural Shine Protectant Wipes is good for navigation screens, LCD, and clear plastic.
Your suggestions are most welcome!
