skippy1969 said:This is what I use. It works great!
You can even use it on some painted plastic.
Even on headlights,but it is a little "light duty" for that.
http://www.meguiarsdirect.com/detail/MEG+G12310
What do you think it's best for, scratched tuners, or hazy tuners?skippy1969 said:This is what I use. It works great!
Reli said:What do you think it's best for, scratched tuners, or hazy tuners?skippy1969 said:This is what I use. It works great!
Who sells this stuff?Jwrok707 said:
THAFUZZ said:Who sells this stuff?Jwrok707 said:
Reli said:Which product do you use to polish tape doors & tuner glass?
I also need to polish my car's plastic headlight covers, and there is polish specifically made for that, so maybe the same product could pull double-duty![]()
I found that one of my local hobby shops sells it. Try to find a model / hobby shop in your area and give them a call.THAFUZZ said:Who sells this stuff?Jwrok707 said:
BoomboxLover48 said:Reli said:Which product do you use to polish tape doors & tuner glass?
One way is to polish the polycarbonate lens and remove the surface oxidation and scratches, but you may have to repeat it to maintain it. It is a temporary fix.
http://www.meguiarsdirect.com/product_detail.do?q=4847
The best way is to get a UV Coating on it after cleaning the surface. Once you have the UV coated Headlight lens cover, that coating it will last for many years. Most cars made before 2003 had no UV Coating on the head light lens and that is why it looks all blurred. All new cars out in the market nowadays have the UV Protective Coating on it.![]()
I remember seeing them refinished at the used car dealership with hand held UV cure lamps. Actually I work in the research area for coatings.
