Belts For Cassette Deck Sharp VZ-2500
prg333
My Cassette Deck is acting up. Only the left reel will turn. The right take up reel will not move. I can hear
the motor run, when play is pressed with no cassette in. It will rewind and fast forward.
I believe the deck has 3 belts. One for FF and Rew. One for Play function, one for the Capstan.
So i would like to get to get a proper fresh set of each of the 3 belts. Where
can I order the NOS belts?
Thank you
Peter
Alberto
You can get the belts at turntableneedles.com and use the "Find My Player" and it will give you all belts and sizes. I think the take up reel not turning is do to a worn out Idler Tire.
